Anyone near Detroit?
Mccoy
Geotechnical
Nov 9, 2000
907
Following a discussion on statistical treatment of penetration data in a riskanalysis forum, the following request was sent. Not perfectly relevant to the discussion (it was foundations, not landfills). Maybe some of you is working in Michigan or surrounding areas and can get in touch with the guy. Maybe he's interested in a full probabilistic study, and we might propose something interesting (I would be glad to carry out the required Montecarlo analysis - no way though I can take a flight and have a chat with Mr. Trigger!!).
I'll e-mail Mr trigger and say I forwarded his request to some of the best in the field!
Do have any references (papers, field studies case studies etc) to the
suggested Monte Carlo application to this landfill geotech analysis
suggestion?
I am looking for experts in analyzing how to build on municipal
landfills also - any references?"
Grant R Trigger
Honigman Miller Schwartz and Cohn
2290 First National Building
Detroit, Michigan 48226
phone 313-465-7584
fax 313-465-7585
grt@honigman.com
Actually MRM and jdonville are near the Motor City - home of those "once again" bad boys of the NBA where Wallace has to beat up his opponent to stitches to be sure to get him out of their series with King LeBron!
[cheers]
McCoy,
I'm fairly close to Detroit.
Would you be able to provide a link to the riskanalysis forum discussion thread?
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
The views or opinions expressed by me are my own and do not necessarily reflect the views or opinions of my employer.
Jeff,
that's not a forum like this one, more of a mailserver run by a federal agency, where you ask and answer thru mail messages, a little awkward, as a whole. If you wish to subscribe I'll let you know how, right now I really do not remember.
Back messages are lost, though. I'll paste the whole "thread" regarding this geotechnical discussion. By the way, Dave Gillette who mailed the latest answer, has been invited in this forum and hopefully we'll be able to further the topic of lack of representativeness of vertical soundings.
Mr. Trigger has already read my mail:
McCOy said:
Dear Grant,
I do not know of any specific references to Montecarlo analyses of landfill
projects. It is a relatively recent addition to geotechnical engineering. As
a matter of fact, in this field it is preferred to carry out FOSM/FORM
analyses, which are approximate uncertainty propagation methods,
traditionally used when processing power was scant and not readily
available.
A Montecarlo model can be applied to any geotechnical solution, and is an
advanced way to define quantitatively risk of failure, allowing for the
variability and uncertainty of all input parameters (soil strenght and
indexes). What is needed is just the same input parameters you use in
traditional, deterministic analysis, sometimes with a different sampling
strategy. I read a couple of generic studies and shall see if I can dig 'em
up for you.
About experts, I forwarded your request to a group of the best practicing
geotechnical engineers in North America I'm in touch with. I'm not sure
wether anyone is living near Detroit, though. Someone might get in touch
with you or forward your request to local engineers.
I've done specific Montecarlo studies in foundations, but I live in Italy.
If you would like to further your project, I would be available but a local
correspondent - geotech - would be a must.
Best regards
Luca Nori
And this is the mail exchange at the riskanalysis server
discussion said:
Hello to all,
Italy has just issued a construction law based on limit state design
(similar to LRFD- load &resistace factor design- as known in USA and
Canada).
This entails a probabilistic analysis of capacity and demand to define
probability of failure as P(f) = P[(C-D) < 0] where C-D is the performance
distribution of the structural system subject to loads and resistances. Now,
this law allows also a semiprobabilistic assessment of stability, taking
point estimates of the distributions called "characteristic values"
(adopting the definition of Eurocode 7). These point estimates are the 95th
percentile for loads, the 5th percentile for resistances. Problems arise in
the definition of the characteristic value for soils. A current
interpretation of EC7 would be that characteristic values for soils would be
the 5th percentile of the distribution of the mean, when failure surfaces
are larger than the typical scale of fluctuation of the investigated soil
property. Assuming we are in this condition, if I have, say, 5 samples with
mean 38, STD 4.85 (assuming a normal distribution of the population):
5th percentile of the mean = 38-2.132(4.85/2) = 32.8
Now some field tests, called penetrometers, measure soil strenght at
discrete intervals, by the hammer blows needed to ensure a certain
penetration into the soil (let's say 20 cm to 1 foot). This is similar to
some sort of a continuos, discrete sampling of a signal or random process
(soil properties along a profile may be similar to stock-market
fluctuations).
In this case I have, as a dataset, a collection of spatial means. But this
will also smooth my signal (smaller variance), so if I follow the above way
to determine the 5th percentile of the mean, I'll come up with an higher
value, which in fact is the characteristic value not of the soil, but of a
smoothed property of the soil.
At last my question: do you know if there is a way around this problem
(which I have to tackle also in other areas, such as vibration
measurements - instrumentation circuits sample the signal with user -defined
temporal means). Changing the field tests is often not an option.
I hope I've been clear enough.
Best to all
Luca Nori
<At last my question: do you know if there is a way around this problem
temporal means). Changing >
Have you tried a kriging program with a nugget effect (e.g.,
Best,
-- Tony
At 10:45 AM 3/6/2006 +0100, Nori Luca wrote:
>A current interpretation of EC7 would be that characteristic values for
>soils would be the 5th percentile of the distribution of the mean, when
>failure surfaces are larger than the typical scale of fluctuation of the
>investigated soil property. Assuming we are in this condition, if I have,
>say, 5 samples with mean 38, STD 4.85 (assuming a normal distribution of
>the population): 5th percentile of the mean = 38-2.132(4.85/2) = 32.8
This formula looks like that for a lower 95% confidence limit--the -2.132
evidently is the 5th percentile of Student's t with four df--except that
sqrt(5) has been replaced by 2. What is the theory behind this
formula? And what exactly do you mean by "the distribution of the
mean?" Are you trying to compute a confidence limit for the mean
characteristic value of all soils within the study region, or are you
trying to estimate a percentile of the sampling distribution of the mean of
five independent random samples of soils in that region?
>(soil properties along a profile may be similar to stock-market fluctuations).
>way to determine the 5th percentile of the mean, I'll come up with an
>higher value, which in fact is the characteristic value not of the soil,
>but of a smoothed property of the soil.
If I have understood this correctly, what you are saying is that you view
every penetrometer value as measuring a vertically averaged quantity, but
you would like to estimate statistical properties of the "soil"
itself. This is known as the "change of support" problem in
geostatistics. It is well discussed in Journel and Huijbregts' classic
text "Mining Geostatistics" (c. 1978). The solution requires estimating
the vertical component of the variogram (which is indeed very much akin to
using the correlogram of a time series). The extreme cases are (i) a "pure
nugget" effect, having no vertical spatial correlation, and (ii) perfect
correlation. In case (i) the solution is a deconvolution and in case (ii)
the average quantity coincides with the point values (so that no numerical
adjustment is necessary). The variogram describes all intermediate
cases. The change of support methodology accounts for varying amounts of
vertical correlation in order to perform a kind of deconvolution of the
averages.
In many cases, however, one does want to compute average or bulk properties
of the soil. For instance, to assess its permeability to vertical flow
through a given horizon, we would want to estimate a suitable mean of the
vertical permeabilities throughout that horizon. Therefore it is not
immediately clear whether it is appropriate or not to use a "smoothed"
property such as a blow count. The answer depends on how the blow counts
will be used for subsequent modeling or decision making.
--Bill Huber
Tony, Bill,
thanks for your tips, you have independently suggested to me the same
solution, and I'm going right into the study of spatial statistics and
variograms. Hope deconvolution won't be a major problem. Tony, I just saw
the freeware on the SADA website, I'm going to download it right away.
Besides:
of
I'm sorry I wasn't more specific, I'm trying to estimate, from the sampled
values (along a vertical profile beneath or nearby the foundation
structure), the 5th percentile of the distribution of the population mean.
This would be the Eurocode7 "characteristic value". The formula is just what
you say, only using sqrt(n-1) rather then sqrt(n) as the st.deviation
scaling factor, my source for that being David Vose's book on QRA . If you
have a reason to believe sqrt(n) may be more appropriate for this problem,
I'll trust you and just change it.
"pure
> averages.
Your understanding is right, I'm interested in estimating the soil
properties knowing only the vertically averaged quantities. Are you speaking
about the real variogram of the soil properties (coming from not-averaged
measurements)? We would not know it, although the vertical spatial
correlation can be estimated from the literature for various soil groups.
properties
As a matter of fact, Eurocode7 suggests that, for large volumes of soil
involved (in the failure process) the bulk property to use is "a cautious
estimate of the mean value". This rather obscure sentence is mainly
construed as referring to the 5th percentile of the population mean. So,
knowing only the vertically averaged quantities (blow counts), I should
estimate the soil properties (not averaged) and from there figure out the
5th percentile of the population mean, to comply with EC7 specs.
Interestingly, if the model does not involve large failure surfaces (i.e.
isolated foundation piles base failure), some codes and authors reccomend to
use as a characteristic value the 5th percentile of the sample itself
(usually parameterized as a normal pdf). The rationale would be that in
large volumes-profiles random fluctuations around the trend (noise) would
cancel out and the arithmetic mean of the properties would govern the
failure mechanism. Conversely, the fluctuation itself would govern, hence we
would be in a more unfavourable condition (the 5th percentile of the sample
mean is lower than the 5th percentile of the population mean ).
(David Gillette writes:)
I would like to caution you about using statistical analysis of soil
properties to infer the mechanical properties of the soil mass on a gross
scale. This is a topic that has occupied much of my attention for the last
25 years.
For a compressibility problem such as settlement of a building, the
vertically averaged stiffness can be a pretty good representation.
However, for strength problems, it is the weakest link in the chain (the
weakest layer) that governs. What's needed is an average over a potential
failure plane for a slope or foundation. Vertical averaging can be
dangerously unconservative.
Penetration testing cannot measure strength. It must be interpreted using
correlations and/or theoretical analysis of the soil shearing around the
tip of the penetrometer. Impact-type penetration testing ("standard"
penetration test, Becker-hammer penetration test, or the Japanese large
penetration test), even more than steady-push testing (cone penetrometer
test), is heavily dependent on empirical adjustments and correlations based
on very heterogeneous data sets. For a given soil, the SPT measurement is
actually a function of the lifting mechanism for the hammer, the operator's
skill and fatigue level, the condition of the pulleys, the style of hammer
(even among "standard" hammers), the type of drill rods, whether the
sampler is used with a liner, drilling fluid, and plenty of other things.
The CPT has fewer things that can go wrong with it (and is preferred
whenever soil conditions permit), but it too relies on semi-empirical
correlation factors that are sensitive to stress history of the soil,
small-scale layering (such as varves), plasticity index (essentially a
measure of how much water a clay can absorb and still act as a solid), and
anisotropy. With any soil strength testing, statistical variation in the
raw data (SPT blow counts or laboratory strength measurements) generally
does not come anywhere close to capturing the uncertainty in the soil
strength. (Sixteen years ago, I fiddled with a Dempster-Shafer
weight-of-evidence approach, incorporating the engineer's judgment/voodoo
of what the test data actually mean, and conflicting/corroborating results
from different types of test.)
I don't have serious heartburn with the 5th percentile/95th percentile
approach sometimes being a reasonable and inexpensive way to reach a usable
result, but the 5th percentile MUST come from strengths determined for the
materials actually involved in the potential failure mechanism, NOT from
vertical averaging of the raw data.
Best regards,
DRG (Dirt, Rocks - Geotech)
I'm sorry, I missed the last stage of the discussion, the one which probably caught the attention of Mr. Trigger:
last said:
Hi David, we've already come across once in the eng-tips forum, we share the
same interest in probabilistic analysis (I go by the nickname of McCoy).
You write:
I agree with you, the failure surface follows the maximum entropy (least
resistance) path. Only, in my context, compliance to regulations and
low-budget foundation projects, it's impossible to have a good sample
density, representative of the whole potential failure surface. Please note
I'm ruling out slope problems, where automatic search models of the most
likely, least resistance path have been proposed.
> tip of the penetrometer....
What I would do in a full probabilistic analysis is to work out a
distribution for the blow count, and from there run Montecarlo simulations
of the correlation model (from blowcount to soil resistance parameter). In a
semi-probabilistic analysis, with low-percentiles point extimates , I would
go either way, correlating before or after, treating correlation quantities
as scalars.
I saw your article published on the ASCE manual (1996). I didn't read it in
detail because I've not studied imprecise probability yet , but sure it's a
promising field in many areas.
Eurocode 7 is very realistic in that it stresses the engineer's judgemental
capacities and statistical analysis is not mandatory. Also, Bayesian
analysis is suggested, due to the value of prior experience. Nevertheless,
if I have to comply, I prefer to be legally-wise on the safe side (formally
following the specs) and apply the 5th percentile rule coming from
statistically treated, bias corrected data. I would also apply Bayesian
analysis with conjugated distributions, coming up with a posterior by which
I'll figure out the 5th percentile.
usable
May be you can suggest a practical and not too expensive sampling procedure
for that, since the shape and extension of potential failure surfaces in
foundation problems are usually well known. Maybe that's best left to more
specific fora (let's meet at eng-tips, I'll e-mail you about that).
Best,
Luca
McCoy,
Please don't say that I said so (as I don't know for certain), but based on his response to my request for a description of his needs, I have the suspicion that Mr. Trigger is looking for an expert witness or 3rd party review to help in a lawsuit (Honigman et. al. is a law firm).
Jeff
Hello, and now that I'm in the club, I'll email you each a beer. (Thanks, McCoy. I'll try to think of something intelligent to say about the exploration program.) I got a chuckle looking at some of the old discussions of music and Christmas greetings. Just like MySpace.com for the geotechnical set.
I tried to post this yesterday but must have fumbled something. I had gotten an email from Mr. Trigger, asking if I knew anything about "special foundations" on land fills or could give him references to look at. I know very little about land fills them, so I steered him to for Ed Kavazanjian's recommended Top Ten papers on municipal solid waste as a starting point. According to Mr. Trigger is both a lawyer and a PE, and specializes in environmental law.
Best regards to all.
DRG
The misterious Mr. Trigger, as a recent message on the riskanalysis mailist advised, left the Honigmann firm and is now working for a real estate (and development?) company.
So he was planning his move in advance.
