enginesrus
- Aug 30, 2003
- 1,016
Will they ever learn a tin can with no pressure relief system, is just not the proper pressure vessel.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
If this keeps up, the "solution" will be that production of air bags will become a third rail that no company will touch.
More like a gun rather than a pressure vessel.enginesrus said:a tin can with no pressure relief system, is just not the proper pressure vessel
enginerus said:a tin can with no pressure relief system, is just not the proper pressure vessel
thebard3 said:More like a gun rather than a pressure vessel.
enginesrus said:Will they ever learn a tin can with no pressure relief system, is just not the proper pressure vessel.
The inflators use phase-stabilized ammonium nitrate (PSAN) as a propellant that has been known to result in violent explosions and send metal shrapnel into the faces of vehicle occupants.
ARC Vice President of Product Integrity Steve Gold wrote that NHTSA’s position is not based on any objective technical or engineering conclusion about a defect, “but rather conclusory statements regarding hypothesized blockage of the inflator orifice from ‘weld slag’ and a subjective inference that a defect exists based upon the occurrence of seven (7) field ruptures in the U.S.
Yet, we still have cigarettes and bouncy houses....wayne440 said:If this keeps up, the "solution" will be that production of air bags will become a third rail that no company will touch.
