bootlegend
- Mar 1, 2005
- 289
I am looking at a bulk material storage bin and thinking about the many cycles of loading and unloading. Suppose I have simple span floor beams with a "floor" plate bolted to the top flange of the beams. What case would be appropriate for the fatigue checks on the beam at the bolt location? Table A-3.1 (15th edition) category 1.5 is for members with drilled or reamed holes but only lists two options: pretensioned bolts, with a threshold stress of 10 ksi, or empty holes with a threshold stress of 7 ksi. I'm planning on non-pretensioned bolts. I can't imagine a snug-tight bolt would be a worse condition than the open hole. Thoughts?
