abaqus rotion using dynamic implicit
kevin biju
Student
Oct 20, 2020
1
Is it possible to apply a multiple time varying load in abaqus each working at different intervals at different location on a high speed rotating if yes how can it be done?
i am designing a 4 cylinder crankshaft so i need it to rotate at a very high speed and i need to apply a varying load at crankpin
i have managed to rotate the object but when load is applied and i have used equally spaced amplitude for it for the top 2 cylinders the amplitude is 1,0,-1,0
and bottom two is 0,-1,0,1. the time period is 200,initial is 0.01 minimum is 1e-005. boundry condition has been applied on bearings and coupling is given on the main journels and bearings.
it does not show the loading in the result and it shows an error
and for rotation only it shows error but it rotates in result
Any help would be very much appreciated
[highlight #EF2929]Student forum QC expert system v0.11 alpha
Recommendation - Need to improve question.
A search engine seem to find several approaches relevant to this problem
Debug 89882299[/highlight]
Cheers
Greg Locock
