Abaqus - non increasing load(TF2)
SofiaB
27
Hello everyone!
I am analyzing an SHS steel truss, simply supported, with concentrated forces (in Newtons) applied in the top nodes. The loads are applied in reference points that are constrained, type coupling, to the section of the chord. All the top nodes have a boundary condition to prevent out-of-plane displacements. I'm using a general static analysis and a nonlinear material.
Since what I want to achieve is the force-displacement curve of each of the truss nodes to analyze the joint's behaviour, it's important to study them above the yield limit. For that, I purposefully applied a big load of 500 KN. The problem is the results for TF2 did not reach 500 KN. In fact, node 3 for example, reached 83 KN before the max number of increments and after it remained constant, not reaching the yield strength. The same happened for de U2, staying at 107 mm which obviously does not correspond to the values obtained with previous analysis in SAP 2000. Von Mises stress values are also much smaller and the deformed shape did not show any type of buckling. Can someone help me understand why Abaqus doesn't continue to increase the load??
I will leave some images for a better understatement. Thanks in advance!
Which type of analysis is that ? Because you've mentioned general static but images indicate Riks step. If you perform Riks analysis, you have to keep in mind that this is a specific method, it solves for displacements and loads at the same time so load magnitude is additional unknown. You may want to compare the solution obtained with Riks method with other approaches (general static or dynamic quasi-static). But this structure may simply not be able to reach higher loads in nonlinear regime.
I agree with with FEA way that a general stativ step is what I expected and what I would use for the kind of analysis you mention.
Therefore I would change to a general static step and see if the whole load can be applied with convergence. If some yield instability happens you will see it.
Take care when looking at the stresses in the elements, as they depend on the location (section points). For truss elemens there should be no problem though.
Andrés
annelysis GmbH | Engineering Excellence |
