Abaqus Nodal Force Diagram 1
MegaStructures
376
Is there any way to show a plot of nodal forces (with force arrows) in Abaqus, similar to what is shown in FEMAP/NASTRAN below? So far I con only figure out how to show resultant forces on a cut.
“The most successful people in life are the ones who ask questions. They’re always learning. They’re always growing. They’re always pushing.” Robert Kiyosaki
Check the documentation chapter "Producing a symbol plot of free body nodal forces", it explains in detail how to create a similar plot. The Free Body Cut tool can also be useful if you want resultants.
Unfortunately the documentation is very bad for that chapter. The directions are basically "make a Free Body Diagram" good luck figuring out how
Basically, what you have to do is:
- request field output of NFORC variable before the analysis
- once the analysis is completed, open the results, use the displayed output variable selection panel and switch to Symbol instead of the default Primary
- select the FREEBODY variable instead of the default output
- choose a component or resultant
Thanks FEA way
