Mous1747
- Apr 11, 2013
- 91
i have 3 Identical interchangeable PSVs on one P&ID, they are installed on the same line ( pump discharge line)
all 3 PSVs have the same size, class and set pressure. they are even the same manufacturer P/N
my problem is those 3 PSV's have 3 different tag numbers/Part number on the P&ID which causing major confusion to the operators and maintenance
my question is would it make more sense to have the same tag number/part number on all 3? to eliminate the confusion
