Upper limit for soils' bearing capacity (ULS)
MramJ
6
Hi everyone,
I have a geotechnical report that provided an Ultimate Limit State (ULS) bearing capacity of 2000 kPa for silty sand soils with N-values greater than 50 (reaching about 70 blows per 0.3 m). My question is: Is there an upper limit to the ULS value where a geotech would not consider for soils? I ask this because I’ve noticed that similar or even lower values are typically given for bedrock. For example, according to CEFM guidelines, a preliminary design bearing capacity of around 1000 kPa to 4000 kPa can be used for metamorphic rock (medium to high strength). Does this indicate that there is a practical or theoretical threshold beyond which soil ULS values are not realistic? Could someone please clarify this?
Thank you
Different soil and rock types will have typical ranges - your metamorphic example means that they will have tested a bunch of different rocks consistent with a "metamorphic rock" description and that's where most samples fell
There is probably a material more firm than 'metamorphic rock' that will pick up at the higher end and give better capacities
There will be a high end where the materials encountered at earth's surface just don't give higher bearing capacities - we're not expecting to find high-grade steel alloys littering the earth's crust neatly under our foundations, are we?
As someone that also does a lot of shallow geotechnical work...I commonly cap the ultimate capacities I give to what I consider are realistic 'good enough values'
I do this to lead the engineers to using more distributed foundations, rather than trying to chuck down big point loads
This is a safer approach that leads to better overall building performance
I'm primarily a structural engineer so I think I have a good feel for what is realistic in these cases
I agree with GAC, we typically cap it at 400kPa allowable (i.e. 1200kPa ultimate) for soils. In reality there is no limit to ultimate bearing capacity. Its what ever bearing pressure that results in a shear failure i.e. plunging failure, which mean that even with a small/negligible increase in load there is lots and lots of settlement.
Which leads to the next point, its dangerous for a report to include such high capacities with out adding some text to you needing to check and allowable bearing pressure based on your settlement limit.
Usually the limits are governed by local practice, conservatism / comfort level, and pragamatic concerns rather than what a formulae will tell you. Most foundation problems are really governed by settlement and differential settlement in reality.
Footing width should be provided for bearing capacity check
